dyoung14
Is getting worn out
mine is a 15 year old fan, 15 year old water pump, and 24 year old untouched radiator and i have never much past 200 with the fan, i have seen 210 pulling a grade with no fan but 190 with the fan
Dont know why so many have issues with replacement or factory fan clutches.
I bought a Hayden fan clutch at napa 2 months ago and cant get this thing to go over 210, even pulling long grades and you know how hot Vegas gets.
I notice that it fully locks in between 205 and 210.
Even with my old factory clutch, it was fully locked in at the same temps.
Best get another to throw behind the seat at the rate haydens fail . I got to where I refused to install the things on customers cars the failure rate is so high on those things
yes the fan barely crawls along but if you look at the shape of the blades on that manual compared to an electric your answer is there. the manual fan has a larger surface area and more of a rake to them then an electric setup. thats why it is much louder then then an electric setup as well.
Just wondering, do all Hayden clutches typically kick in around 210 degrees?
I don't know the history of my fan clutch (it's the same one that was on the truck when I got it in 2001, and it's always acted the same), but it kicks in between 200 and 210 degrees...and my coolant's NEVER gotten warmer than that IIRC most original fan clutches don't kick in until 220 or even 230? I'm just curious...I certainly have no complaints about my fan clutch...
Hmm... I would take you to task on that and ask you to prove it. I used to think the same thing, until I converted to electric. I studied side by side my electric fan blades and the big metal fan. I agree, at casual observation, the metal fan appears to have more guts, but if you get out a tape measure, and start comparing square inches, my dual Tauras fans have more surface area than the single mechanical fan. The pitch of the blades is higher on the mechanical because it has to be. There are fewer blades. The noise is actually more due to poor design than higher efficiency. Things like pop rivets just randomly drilled in the blade to balance it. I mean... c'mon. That creates a ton of turbulance. Add to that the fact that the factory fan shroud forces more of the air to be concentrated in and around the center, versus my dual electrics that put an even pull on the air across the rad, it all adds up to better design, higher efficiency and superior cooling. Just look... the factory fan, about one third of it was where the bottom tank of the radiator is. Of course, this is the wide non-AC rad. Hopefully this is one of the reasons they got away from this design. I mean.... how stupid. What were they thinking?
