For a little background on this problem:
http://www.oilburners.net/forums/showthread.php?t=39738
Here's the deal: I replaced the vacuum pump as was recommended in the above thread, but the 'Rear Antilock' and 'Brake' lights have come on since. I've put about 120 miles on it and they've only come on twice in that time, whereas before I replaced the vacuum pump the lights would come on after the truck had been running for five (or less) minutes. However, I hadn't noticed the brakes locking up like they had been.
A couple of days ago, I took the truck out on a 15-mile trip to get the engine warmed up. Towards the end of it, I decided to brake fairly hard to see if the brake lock-up problem had been solved. It had not.
Yesterday I went down to the dump to get rid of a load of garbage. I pulled in, shut off the truck, unloaded the garbage and got back in the truck. I started it up, put it in gear and released the clutch. The truck acted like the parking brake was on. It wasn't and the 'Brake' light on the dash was not lit up. I pressed down on the parking brake pedal and there was very little resistance. I released the parking brake, put it in gear and again tried to leave. It still acted like the parking brake was engaged. I left with the brakes dragging. After a couple of miles, they had released and were not dragging.
This is leading me to believe that there's something going on with rear brakes. I read my Chilton's and reviewed the procedure for obtaining codes from the RABS I system. (I'm pretty sure that's the system my truck has, I couldn't find a control module behind the glove box like the RABS II system.) I grounded the diagnostic connector with the ignition in the RUN position and the 'Rear Antilock' light came on while my jumper cable was connected to ground, but as soon as I released it, the light went off. According to Chilton's, if you ground the connector for 1-2 seconds, the 'Rear Antilock' light should start flashing in a sequence to allow for a reading of the trouble code.
One odd thing to note about the RABS I system in my truck: according to Chilton's, the diagnostic connector should have two halves that you need to take apart in order to ground the black/orange wire. My truck doesn't have two halves, it's just got the one black/orange wire hanging free (with a plastic connector half protecting the bare metal). I searched around and couldn't find the other half.
Does anyone have any experience or input that might be helpful?
