I'd like to see what any of the members here have for waste motor oil/waste veggie oil filtration setups.
The more home-made the better.
Its not done yet but you kinda get the idea. Its a gravity feed system. First filter is 10 microns Second is 5 Third is 1 micron and the last is a golden rod water block filter.
Where did you get those filters?
I added the water block filter as a just in case thing.
10 micron into a 2 micron.You must be registered for see images attach
how long have u been running that fiill-rite and are you pumping 100% engine oil?
I find when i use mine to pump oil from a barrel you can listen to it labor more then just diesel and i wonder if that will be the death of it
Alex, what are those pot looking things in your filtering setup?
Should I assume the 'water block filter' is specifically designed to remove any water that the first filters did not?
