GOOSE
Happy IDI'er
If you go to my last thread,
http://www.oilburners.net/forums/showthread.php?t=39118
you will see the effort and troubleshooting I went through to get to where I'm at. Curiousity killed the cat and I pulled the head off tonight. I was hoping to find a fault in the head gasket but didn't happen like that. I then rotated the #4 cyllinder to BDC and found what seemed to be a gouge in the wall. After cleaning it up I noticed it was a rather long crack that the pics do not do justice to.
Now the Logger will be downed longer than expected because the spare motor will require a new level of freshening up. Oh well, at least the spare is there and paid for.
It was at least encouraging to see that the gasket held up to 14-15 psi of boost and at times towing a 22,000lb trailer.
That is murky water laying in the rockers and note the discoloration of paint indicating some heat on the exhaust side. Never saw more than 1100deg and only that for a very short time. Probe is on the up pipes.
Spare motor is coming out soon!! I might just run it natural and find a block to build up with studs and other goodies. Turbo was put on in '92 so it probably should be gone over as well.
I can't believe that cyllinder made 245psi of compression!!!
