500psi cranking HUEI pressure, 70psi fuel pressure...One constant in the whole deal - P0340 cam sensor fault. I told him to buy another new one and try that - otherwise I would say it's time to peel the engine harness open or replace it...His CPS is maybe 6 months old as is the IPR. Here is my gauge setup hooked to the head. This stuff will run you about $300+ from CAT - the line is good for 6000psi. Still no cranking speed on the tach or tuner - hence the call for another CPS....Loving my IDI more all the time...
