jperecko
Diesel Ape
I was going to post this in one of the many other intake threads but it likely warrants its own thread.
I think that all this ram air intake business is rather silly. The shear volume of air that engines take in is immense and no matter what kind of funnel you have at your hood, you are not going to be making a significant difference.
People also argue that these suck in cold air instead of hot under-hood air. This MIGHT apply if at or near a stop... but as soon as you get going, there is so much air rushing in from the grill and below that there is no time for the air under the hood to heat up.
On a Benz forum, one member made just an open underhood setup which could also be hooked up to a cold air intake from underneath. With or without the cold air tube, he got the same mileage results.
I would do some sort of removable setup on my truck but is far from drivable right now. So... pretty much all these claims are just that, claims. But I challenge someone with a ram/cold air intake to do a test run with their fancy intake and then just hack open the intake and leave an open element. Maybe a set ~100 mile course with a refill after each run.
Prove me wrong! I love to learn from my mistakes. But if I am right, I might save some people from all kind of troublesome fabrication of intakes for little/no benefit.
Thanks for putting up with me.
