Is my injector pump toast.
brewer
san diego CA
Oil sump over full, coming out breather. Rough idle. Low oil pressure light on.
Where can I find info on removing pump from truck? Is it that hard? My factory shop manual show nothing on the injector pump.
Any help would be appreciated.
Thanks.
brewer
san diego CA
That's it. Smells like diesel big time. I'll try the lift pump first. That's an easy fix. How do you tell the difference between lift pump and injector pump?
Thanks.
bigoilburner20
circleville ohio
Lift pump is on the side of the block like an old gas job mechanical pump I would reccomend a carter electric to perminently fix but go get a new mech lift pump at ford if possible most auto store remands suck
Lift pump is on the side of the block like an old gas job mechanical pump I would reccomend a carter electric to perminently fix but go get a new mech lift pump at FORD if possible most auto store remands suck
You're in the dodge Cummins section. LOL
So get it from DODGE or go electric.
bigoilburner20
circleville ohio
Yea I figured a ford part might help him lol just saying it might be better then a dodge part lol but thought I was in ford sry
NO_SPRK
User & Abuser
Santa Rosa, Ca
Ive had many lift pumps go out on first gens. Id put a electric lift pump.. plus the thing is not so easy to replace since its so far down on that tall block
Sent from my SCH-I605 using Tapatalk
Definitely buried in there. I'd take changing my psd pump over one. (Haven't done the Cummins one yet, but looks to be a pita)
Any pump Elec pump you'd recommend?
Sent from my USCC-C6721 using Tapatalk
RangerDanger
