Are these transmissions kind of slow?
burtcheca
farmer/cabinetmaker
Live Oak, Fl.
After fighting the algae problem with the '81 300D, now I want to know if the Mercedes with this type of automatic transmissions in 1981 were always kind of sluggish. I know that the rear gear ratio is not the best while cruising but what it's bothering me is that the transmission looks weak or slow.
What kind of test should I run to determine if it needs a transmission job or simply a tune up and cleaning? I went to the mechanic's shop in town today in the morning and he recommended to put a bottle of Seafoam designed to tune transmissions and I did. He says it will take running it for some miles to notice any difference.
I'm thinking I need to remove some transmission fluid now because the fluid level is about 1/2" over the top line in the deep stick. I drove it from town to home (about 1/2 hour) and noticed it was between the lines when I parked it at our farm, before putting the whole bottle of Seafoam in it while iddleing in parking. Then I saw that it was over the upper line about 1/2". A friend here told me not to worry and run it a little around the farm to make sure the Seafoam is mixed well and the level reading is correct.
Any suggestions?
Thanks.
Burt.
Turbo OM617
Never use ANY additives in any lubrication fluids of your vehicle.
The only exception is with diesel fuel in cases of fungi/algae contamination or extreme cold (below -5*f).
Anything with "leak stop" on the bottle will cause damage.
The transmission should shift quickly and firmly at around 3000rpm at normal throttle levels and very firmly at 4500-4800rpm at full throttle.
Sluggish and/or early shifting can be addressed by adjusting the vacuum system to correct specs and installing a valve body repair kit if necessary: http://mercedesforum.com/forum/diesel-performance-49/722-transmission-shift-kit-49014/
ntjapkes
