7.3 heads on a 6.9?
david85
Campbell River, B.C.
I noticed a cheap set of 7.3 IDI heads come up on marketplace in my local area. I know the later rockers can be an upgrade for 6.9 heads, but can the entire assembly be used on a 6.9?
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
Are you asking if the entire head can be used.... it could, you would just need some kind of sleeve to go from the 1/2 in bolt holes in the 7.3 heads to the 7/16 studs/bolts in the 6.9.
No, there isn't enough meat to drill the 6.9 out to 1/2 bolt holes
ih8minimumwage
Eugene, OR
You would have to remember to order two sets of those. Our IDIs use more head bolts than the Ford Windsor engines do. Other than that, they may work.
I doubt that the bolt length would matter since these are just bushings that slide over the bolts. Naturally, they're out of stock though.
