WTB Bricknose Fuel Filler Necks
Giddy-Up
North Dakota
WTB Dually Fuel Filler Necks
I'm looking for both the front and rear filler necks with hoses for my 90 dually. Thanks
i have a spare set of gasser DRW filler necks.
you could modify them
pics in the AM.
off of a 89 F350 2wd DRW
make offer.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
What needs to be done to modify them? I haven't had a chance to compare a set of g@$$er and diesel DRW filler necks, but I have a set of g@$$er DRW filler necks that I either need to modify or exchange for diesel filler necks...
the little hole inside the filler neck will not accept a diesel fill nozzle.
the plate either needs to be drilled out to accept the larger nozzle, or knocked out all together.
i was a slacker today and forgot to get pics.
will do it in the morning....
so here are the pics of both filler necks.
ones out of the truck, one is still installed, easily removable.
the last one is the diesel rear filler neck for my SRW F350 for comparison.
both will come with the inner tubes.
i will need the outters tho.
my best advice is to somehow, knock out the flap from the gasser necks, and use a knock out kit to enlargen the hole...
or a stepped drill bit.
its up to you if you wanna use these. i have never done this, so im not 100% on the modifications.
this weekend... i promise...
the front tank pick up came in today, i can finally do these tanks..
life is hell.
sadly, im going to have to use these.
heres a comparison of the DRW brick nose filler necks,
and the OBS necks i was trying to use.
the OBS stuff was too short.
i ended up taking the gasser necks and drilling them out with a unibit.
just got back from the fuel station and making sure it works with the pumps.
SRW necks
DRW necks
what i did to make them work.
Giddy-Up
North Dakota
So the drw necks are different front to rear? And if you have a diegrinder with a good bit you can open that filler neck completely. That's what i did with my working tank
typ4
Newberg,OR
A sharp wood chisel will carve that flap crap right out, Did it on my dually. I have tank mods to post in my spare time.
i wanna say that the DRW front and rear necks are the same,
but im not 100 % sure.
i picked up a parts truck lastnight on the cheap.
it looks to have the factory filler necks, even tho it used to have a flat bed on it.
these necks and rubber tubes are yours for the tune of 15 bucks shipped.
the rear neck is damaged tho.
ntjapkes
