TWeatherford
This weekend I've been busy putting new battery cables and upgrading to a set of Group 31 batteries. While I was at it, I decided to give my glow plug system the annual once over. All the plugs ohm out good, and since my harness is in not so great shape I wanted to verify that I'm getting 12 volts to them. They're on a momentary toggle switch, so I had my wife run the switch while I used the meter. Before she hit the switch, I was reading 11.5 volts. When she hit the switch, I'd get the expected 12.5 volts.
I haven't done anything to the glow plug system since replacing the plugs and converting to push button over two years ago. I was under the impression that there should be no voltage at all going to the plugs with the key on until I hit my manual toggle switch. I haven't hooked them up yet, as I'm afraid at 11.5 volts they'll burn out in short order besides draining my batteries and putting a big load on the alternator. Of course if I hadn't done that check I'd have no idea about it at all.
Anyone care to comment if I'm correct or not? If anyone could run out and check their truck I would be much appreciative.
