Where's the clutch switch?
Poway, CA
The truck has slowly developed this annoying trait where I occasionally have to slam the clutch to the floor to get it to turn over. I don't think it's firewall flex as the truck drives fine otherwise. I'm pretty sure it's the clutch position sensor, so I ordered one up from RockAuto (Motorcraft, of course). I peeked my head under the dash for a quick second and couldn't find the sensor. PLEASE tell me it's somewhere that's somewhat easy to find and get at.....
Mike
cpdenton
Truck needs paint.
Conway AR
It's mounted on the clutch master cylinder actuator rod. Under the dash, high up, between the brake pedal and gas pedal.
They're not too bad to change once you figure out how it comes off. Lol
Play with the new one first to figure it out.
Also take a peak at the rod bushing.
S-west
Ct
Not trying to hijack the thread but does anybody know what the switch is that the clutch pushes when it's all the way up? My pedal does not come all the way up so it's never in so it can't be inportant. But I'm curious as to what it is.
dsltech83
Ellery,IL
Switch that cancels cruise when you step on the clutch.
DesertBen44
Grand Junction, CO
Before you mess around with that, my truck also recently developed the SAME ANNOYING TRAIT!!!
First start of the day i would have to SLAM it into first, rest of the gears worked alright. had to slam it to the floor to start it also.
My slave cylinder res was almost empty! Not sure where the fluid was leaking because there were no puddles or annything, but keeping a close eye on it now
Check yours before you mess around with switches. other gears worked ok, just first was bad when I first started the truck.
Check fluids,
Check the pushrod actuating arm bushing...I did a tech 101 on replacement of a worn arm
It is not LIKELY the switch, it's likely a worn bushing and pin on the actuating arm. This makes it seem like the switch is not functioning when in fact the clutch is not pressing in enough to make the switch function as it should.
Here you can see the arm is worn out.
http://www.oilburners.net/forums/showthread.php?62040-Tech-101-Clutch-ARM-replacement&highlight=
Hope that helps,
Al
About the cruise control cancel switch... On my 89 E4OD trans rig its located on the brake peddle because I don't have a clutch peddle. On my 79 chevy rig this is also on the brake peddle and its a vacuum switch..
Poway, CA
Checked the fluid. It was full. I tried topping it off, but everything I put in came out when I put the little bladder back in.
Found the switch, too. I was looking over near the clutch pedal itself. Didn't realize it was more towards the throttle. I don't want to bypass it at the moment, but it's a good thing to keep in mind for if/when it ever leaves me stranded.
I'll check the rod and whatnot when I replace the sensor.
Mike
Mike
Check the Rod and bushing now...no need to replace switch if bushing is shot and pin shot...likely the problem not the switch...
JM2CW
having done lots of work on these, those two parts are the key for most part
placidoert
