So i'm in need of new tire set. My current summer wheels are about done, they are 355/65 18". I like the 18" wheels, but i want to change wheel style and what i don't like is at least $100 extra on one wheel compared to 16". So i'm downgrading to 16" and wheels most probably are Mickey Thompson classic II with Swamper Trxus STS Radial on them as my choice. Tires most likely will be 14.5"x36", which are the closest to my current tires. So my question is that which wheel will be better, 16"x10" or 16"x12" wheels? Is there any upsides or downsides if i choose to go with wider wheel which obviously would look much better ;p ? I have airlift air helper springs at the rear, do you think that i would ran into some clearance problem with the wider wheel? Currently tires are quite close to bellows, but then again current wheels doesn't have much negative offset and are only 9" wide.
Or if you have some other comments on your mind, feel free to write. Thanks in advance...
