Thank you!
That is interesting.
I'll be moving on to the rear brakes, after this. But the fact is, at least the passenger rear brakes were dragging. Badly enough to actually brake the truck any time I let off the go pedal. And make it take more go pedal than it should, just to get it moving.
I replaced the long hardline in the rear when it burst. Now it takes off like a bat out of... whatever place bats fly out of.
And when going down the highway, if I let off the go pedal, she just coasts. Doesn't slow down immediately as if the brakes were on.
I figure a flake of rust inside that hard line was letting the pressure through to the brakes, but wasn't letting the fluid back through FROM the brakes.
But that would be kind of the opposite to what you describe.
Except... It could be out of adjustment on the driver's side rear!! I'll find out when I dig into the rear brakes.
Also, if misadjustment were the case, wouldn't pumping the brake pretty hard many times, eventually take up all that slack, and give you a pedal that doesn't just continue to slump?
I've tried that several times, and it just continues to slowly slump, no matter what.
There is nothing dangerous about this. The brakes work normally. And you don't have to push very hard to keep it still at a stoplight. So it normally doesn't bleed down at stoplights. Only when I push harder...
