wat is KDP help please
24valvecory
linglville/tx
hey i no my name says 24 but i got a 1994 12Valve i turn the star wheel pushed the fuel plate up and have a #6 plate on the way but it has an automatic tranny and air filter with strait pipe wat else can i do and wat is the KDP i heard it was bad or something can u help. i could use pictures too still learning about diesels.thanks
smokin69
Always smokin'
Baraboo, Wisconsin
It stands for Killer Dowel Pin, there's a pin in your front gear drive that is used for aligning the case to the block and after time it can wiggle out and jam in the gears and tear everything up. The kit puts a tab in front of the pin to keep it in place and eliminate the danger of your engine dying from it.
