swampdigger
Hey guys... anyone know what the early 80s externally regulated units will put out for a max field voltage? Will they go the full 12V if need be, or are they capped at a lower voltage?
I just mounted a second alternator to be used as a welder, and I'd like to add a second regulator which I can trick into holdings specific voltages between say 20 and 120 volts. Lower for welding and stuff, and 120 for running grinders, lights, etc..
The plan:
So if you have the pot set to feed the full output of the battery terminal into the regulator, it will make the alternator put out 13.8V as it normally would.
If you start turning it down the regulator only sees a fraction of the actual alternator output. It could be jamming out 120V from the alt, but because it sees 13.8V coming out of the potentiometer, it's happy, and holds that field voltage.
At least in theory, anyway......
The plan:
