VHT clear coat on engine?
OldIron82
Northampton PA
Hello all. I'm splitting hairs here at this point but is there any protective benefit of clear coating the engine specifically the exhaust? The exhaust is black VHT 1300° and the same company makes a clear coat for it. I don't think it would be wise to clear the dt360 blue because God only knows if the VHT clear is compatible with it. So should I clear the exhaust for longevity protection, or is clear more for looks? Thanks
Macrobb
North Idaho
Looks. Pretty sure none of my exhaust has ever been painted at all, and it's not the outside that rusts out usually - it's rust from the inside due to the high temps?
chillman88
Central NY
My understanding has always been that clear coat is more for UV resistance. On the exhaust I wouldn't bother. It's more important that the recommended heat cycling is followed for the paint to "cure".
OldIron82
Northampton PA
Thanks guys. I forgot about the heat cycling! I'll have to pay close attention to that once she is running!
bob123456789
