Mr_Roboto
This is on my 85 F350 in my signature. Both turn signals work fine, until you press on the brake pedal. Thinking maybe it was a load issue (tons of lights on this truck) I installed an electronic flasher unit. Same thing, no change.
It's been a while since I've dealt with these older trucks. Is this going to be a bad turn signal switch, a wiring problem or something else?
OK, I did a little more looking. When the turn signal is active, both rear lights are actually flashing. The front turn signal lights work properly.
I've checked the grounds at the rear lights, and also checked for burned out filaments that would short between the turn and brake circuits. Those things checked out OK.
