Ironman03R
I have a thought...
The limiting factor to these engines is high EGT's so what if a larger turbo was used with a bigger more efficiant compressor, with intercooler of course. I know everyone has their ideas of "Safe" boost levels, but from what I've been readin, 15-25 might be possible with head studs and a turbo thats not workin so hard to make boost that it looses it efficiantcy and super heats the air. Plus some more boost might be possible with water injection. I know a big turbo will make way more boost that a 7.3 could ever use so it would have to have a wastegate.
So I guess my question is will a higher volume of cooler air help to keep EGT's under control or make it worse. Im not in the middle of any extreme build up I'm just throwin ideas out there. There are a lot of engines out there that run way more boost with similar or more compression, I think the internals can handle more than we are givin it.
Opinions?
Opinions?
