Turbo boost
MARQ2277
caldwell, idaho
There has been some discussion on boost when an after market turbo system is added to the 7.3 idi engines. Anyway, I decided to ask ATS how much boost my 1990 F250 4x4 ATS turbo system made at both idle, and at WOT. The following is a what was sent to me:
"RE: ‏
You may not know this sender.Mark as safe|Mark as unsafe
Sent: Mon 7/14/08 8:31 AM
To: [email protected]
The turbo system will not make any boost at idle and will make about 13psi or so at full throttle. It all depends on your fueling though.
Bryan Vilaubi
ATS Diesel Performance
Email: [email protected]
Toll Free: (800) 949-6002 X-107
Direct: (303) 327-4728
Fax: (303) 431-0135
Sent: Saturday, July 12, 2008 11:30 PM
To: Kelli Weaver
Subject:
I HAVE YOUR ATS TURBO SYSTEM ON MY 1990 7.3 IDI, AND I LOVE IT. BUT I HAVE A QUESTION. HOW MUCH BOOST DOES THIS SYSTEM PROVIDE (ABOUT), WHILE AT IDLE, AND AT FULL THROTTLE.
MARQ"
I copied and pasted the entire e-mail verbatum.
Marq
_____________________________________
1990 Ford F-250 4X4:
7.3 IDI with 120K on the clock:
ATS Turbo with waste gate:
Stage One Injectors (Oregon Injector Service):
Complete Return Fuel Kit (Oregon Injector Service):
DB2 Pump, cranked up with Cold Advance wired permanently on:
4” down pipe, 4” straight through exhaust stopping between cab and bed (no **** on my stuff):
Torque Converter Lock Up Switch (On/Off/Lock-Up):
E4OD Line Pressure Controller (adjusted to fast/firm shifts):
4” lift w/Rancho shocks:
Big Fat Tires on custom rims:
Tows 1985 fully loaded heavy 28 foot RV (my house) everywhere:
forcefed
Newark, OH
That sounds right to me. I'm surprised you got a answer from ATS. You will not see any boost at idle. You can change your boost if you have a wastegated turbo by shortning or lengthening the wastegate rod. I shortened mine and I see about 11 psi boost at about 1800 rpms. I really do not want much more becausse of the high compression. Why are you curious, are you running low boost numbers or just asking to know? Just wondering?
MARQ2277
caldwell, idaho
You are correct. I was not sure. I get told so many things, I just had to try and get ahold of ATS (because my system is an ATS). And, yes my turbo has a wastegate, but I am leaving it alone. I read were some claim almost 30lb at WOT, and all kinds of tales. I was under the understanding from my dad (who as a Cummins), that a regular diesel with regular compression (around 17 to 1) get 25-28lb of boost, and a good after market set up will go 35lb of boost. And than there's the full out high performance who get 50+ lb of boost. I just assumed because of the laws of physics that with 21.5 to 1 compression ratio, it could not be more than 12-15 lb of boost, without breaking things. Anyway I had got different responses of different claims, and I just wanted to know what a stock turbo system on my stock 7.3 IDI made. Because than I can get a better understanding of fuel adjustments, how much hp/torque I may be making. If I can add a water injection system, how much timing can I add, etc. I always feel that, the more I know about a subject the better informed choices I will make.
Marq
_______________________________________________________
oldmisterbill
Grumpy Old Man
Wagoner Oklahoma
He forgot to tell you load and how hard you're pulling also effects boost pressure (harder longer pull-more heat-more boost capability) so many factors.The wastegate should enhance these factors.
MARQ2277
caldwell, idaho
Oh yeh, I am sure there are things that effect the outcome, but I believe that, the max output, that my ATS (wastgated turbo) will produce is about 13lb of boost, give or take, . . . I know that there is a procedure in which a vaccuum tool is used to set the waste gate while the engine is off. In my diesel manuel, it tells you how to do it. And, I know that a good shop (hopefully a good shop was used to install my setup), will correctly set the boost on the turbo, by using the vaccum methode, and than correctly add the fuel, by turning the (roller assembly spring) adjustment which we all know is on the side of the DB2 pump, under the plate.
Hey Bill, how ya doing??
marq
typ4
Newberg,OR
I see 13 lbs with my ats but it has a bigger wheel and an intercooler, with 4 inch exhaust and the wastegate sense line is unhooked. With the stock comp wheel it would only make 10 lbs under full load and I do have the fuel turned up
some:D
Russ... A stock Moose pump will get you way past 15 lbs the way it comes out of the box. I know... The Moose pump is not stock but when I installed mine and saw the boost numbers shooting up past 12 so fast it scared me. I know my motor can handle it but why push things till I know when they break. Soon the Hypermax intercooler will be installed and then..... Towcat knows what I mean......:D
Ironman03R
Risingsun, OH (NW OH)
I have an ATS and a Hypermax turbo, The 7.3 ATS setup gets 12-14psi depending on load. My fuel is maxed on that truck.
My Hypermax 6.9 setup I dont have much experiance with, But tonight it I saw 10psi before I ran outta road. I dont know where the fuel setting is on that truck.
Diesel JD
Gainesville, FL
I could be mistaken but I think if you're seeing 10 psi on a non gated setup your fuel is turned WAAY up unless you have some hills or you're hauling a big load. Bill is right these factors make a huge difference with turbos, probably second only to fueling.
typ4
Newberg,OR
I agree Gary, but my fuel is maxed out and it will roll coal all the way to governed rpm, SOOOO it must be a timing curve in the moose pump. And injector delivery.
I like my 18.7 mpg empty so it works for me.
Also keep in mind I have ported heads and a torque cam and I run out of legal road real quick in 5th gear;Sweet
Preems14
Redcliff, Alberta, Canada
What kind of boost levels will i be seeing with a factory turbo with a stock downpipe and 3 inch from dp back?. Im taking my truck in on saturday to get all my gauges hooked up and then its bodywork time.:D
Preems14
How do i get more boost. I know turning up the fuel can get me a bit more and also a bigger downpipe. Sorry for being a newb im still just learning and i think im doing okay for a 15 year old
FordGuy100
Silverton, OR
Adjust the wastegate, or unplug the wastegate. To get more boost by adjusting it I believe you have to lengthen the wastegate rode, so whichever way turning it makes it do that (more than likely counterclockwise)
and by the way i love your truck i watch the jake brake videos all the time on youtube. I will get some up of mine when i get my license ;Sweet
Thanks man ;Sweet
