coletrain777
Sometimes I put my truck in 4wd and when I shift the transfer case back to 2wd it doesn't come out? The TC shifter moves fine, and the light on the dash goes away, but I am still in 4wd. The truck has auto hubs if that matters. Now this is happening when I put it into 4hi, I very rarely use 4lo. most of the time when this happens I will shift the truck into reverse and drive backwards for 100ft or so, then put it back into 2nd and drive forward and it will be back in 2wd??? What would cause it to hang in 4wd, is there something I should be checking like TC fluid (the linkage seems to work fine)?
