zigg
I've found the thread that was posted previously about the mod to wire the torque converter lockup on my E4OD up so that it can be put on a switch and turned on/off at drivers' command.
I'm interested in doing this. I'm thinking of putting it on an on/off/on switch, wired so that it can be either off, on, or in the original automatic mode for when the wife or someone else drives it.
So, I'm trying to understand the tranny better. If I have it right, the tranny produces heat, mostly from the friction of the fluid coupling of the torque converter. So, can I assume then that most of this heat would not be happening when the torque converter is locked up?
I'm visualizing climbing a big hill in say 3rd gear, to the floor pulling boost etc, but normally, the converter would unlock when the speed got too low, and then there would be a heat issue. If you can flip the switch and keep it locked even down to a lower speed, then you'd be able to prevent as much heat buildup in the tranny!?
Have I got it right, or am I wrong.
I do plan on a temp gauge in the near future to watch things, and there is an extra tranny cooler in front of the rad, but it's not too large.
Any thoughts...?
Zigg
Any thoughts...?
Zigg
