I put a Mr. Gasket #12d fuel pump from auto zone on my truck probably 3 months ago, looks like it is already crapped out on me. Truck was surging on me a couple nights ago, saw my fuel filter wasn't full so I figured I'd change the element in it (original seperator replaced with one of these http://www.tractorsupply.com/dutton-lainson-reg-goldenrod-reg-495-fuel-filter-3958244) changed filter element, worked fine for probably 75 miles back to same thing. Checked fuel pressure after filter 0psi under WOT, before filter 3psi WOT. I occasionally run some wmo and used atf when I can get it form work so, also I might get the opportunity to get all of the WVO I can burn from the school where my wife works. Although when running any kind of waste oil I don't mix it any thicker than 50/50. Should I chance the Carrier pump from gen lightning, or should I get either a holley red or carter p4070?? Let me know what your experiences are............
