velacreations
I've got a 94 F250 7.3L idi turbo. Overall, it is a great truck. There are a few little issues with it (like the AC), but in general things work fine.
Recently, it developed a problem where on cold starts it surges/revs and drops. revs and drops. It doesn't hold up at 1500 rpm like it used to. Once it warms up, it is fine.
It does have a stutter, and I only ever notice it at lights or when idling. It is very faint, but almost like it is missing. I ran out of fuel a few weeks back, and the stutter was really noticeable, so I bled the fuel lines (post IP), figuring air was in there, and that really helped a lot. It still stutters, but ever so slightly, you wouldn't notice it unless you were really paying attention.
It smokes just a little bit on a cold start, just for a second, some grey smoke, and then no more smoke, ever.
It has 250K miles on it, and I don't think it has ever had the injectors or IP changed. The injectors were serviced a year ago, right before I bought it, and they did change out one injector. I am planning to get a set this year, and maybe go ahead and change the glow plugs while I am at it. It starts fine when cold, so I don't think they are weak. Usually turns over for 1-2 sec, and it's up and running.
So, my question is, what do you think is going on with the revving on cold startup? Is the cold start solenoid bad? or maybe the IP advance?
And the stutter at idle? does that sound like a weak injector to you guys?
