Freight_Train
Traitor to the brotherhood
How does the DOT figure up your GVW?Is that actual weight on the ground or is that the max rated GVW of the Truck and Trailer even if they are well below that or is there a special way they rate it since the truck can't haul much if it has a gooseneck hooked to it.......I am trying to figure out if I will need a CDL to drive white lightning with a 25,999GVW goose hooked to it with the big E getting taxied.......or Martyr machine which ever rally I am headed for!
