jonathan
its the fuel pump!! its weak and its not keeping up with the demand.
today i installed a bbc fuel pump bock off plate. now i am just waiting for for my duralift fuel pump to get here. does anyone have any pics of the duralift pump mounted underneath the hood? just tring to get so ideas
I like my pumps as close to the tanks as possible. My experience is that electric fuel pumps like to push rather than pull the fuel. I have some photos of mine on the crew cab mounted on the frame rail near the tank selector valve.
Here is the fuel line bypass of the old mechaincal pump.
Don't use the crap fuel line from Autozone, it's Thailand junk. Get some made in the USA Gates or Goodyear 3/8 inside diameter fuel hose.
Heath
They will sell you the wrong hose if you just ask for fuel hose. You have to ask for the hydraulic oil hose FOR DIESEL fuel. The counter guy will say it's the same, he's WRONG it's not. Gasoline fuel hose will be eaten up on the inside with diesel fuel.Don't use the crap fuel line from Autozone, it's Thailand junk. Get some made in the USA Gates or Goodyear 3/8 inside diameter fuel hose.
My pump should be here on tuesday . Thanks again Doug
Take some shots of how you install it.
I thougt these pumps were made to pull fuel, not push it? Thanks for the great pics, also I like the autozone comeant
yeah, I'm pretty sure these pumps are built to pull diesel up to 20ft(since they sit on Refers)?
nice, simple and clean job on the bypass Heath. I was curious what the ID was on the hard line to make sure I wasn't causing any restrictions to flow.
