Was running just fine, let it sit for a couple weeks and starts acting up. Fires right off, run fine then gets rough and dies, about 20-30 seconds. Have to crank a bit to get to re-prime, runs fine once started again. Scenario will repeat if let sit for a couple of hours. If shut down for a minute, it will start fine, but then idles rough and stays running. O-rings are fine, no other visable leaks present. Tried a electric pump inline and no change, same on both tanks. I have had o-ring leak, but they took much longer then this to affect starting. Really perplexed by how fast it loosing prime and do not like working my starter this much. Maybe the moose is getting tired.
