stacking chips
Camstyn
hoser
asdf
I've got a 125 horse juice/attitude and a 100 horse Maximizer to stack, if I throw a 155 horse Power Pup into the mix how many pieces will my flywheel break into?:fan:
I don't plan to run this on the street, I'm saving up for BD Dyno Day in April so I can run it on the mustang dyno. Anyone have any guesses what kind of numbers I can expect, if she holds together?
Max Power
I would think you would start to run into some bad bursting issues. You also might find that adding a 3rd box might actually lower your numbers.
Got Juice?
Stack Daddy
Juice on max, power pup (no timing on 65 horse setting) and maximizer on 1/2 way (also with no timing should net around 500
too much timing and bye bye headgaskets!
Camstyn
hoser
asdf
Sounds good to me.. The duramaximizer has no timing so would I benefit from running it turned all the way up? Also with the power pup with no timing, what difference would I see with it stacked on the 65 horse level or 95/155? Any point in even buying the 155-upgrade?
Thanks for the advice!
Max Power
GJ, isn't their a 'loop' you can cut on the edge for timing?
Got Juice?
Stack Daddy
Not too certain Max, I believe it is a reroute of a pin wire or 2.
I'll have to find out.
Cam, the Dmaximiser probably could be run all the way up, might just have to do a test and tune session on the dyno to verify each setting.
REM70
