Andylad13
DieselBoy
What would cause a stiff brake pedal with minimal brake pressure? If you can time the stop perfectly with one push of the pedal the brakes work mint. But if you apply them too much and let off alittle, when you push them back down the pressure increases greatly and braking power decreases greatly too! Also in reverse the same thing happends except its a stiff pedal the whole time with minimal braking. It's sometimes scarry!
