homelessduck
All I can say is I had the same issues as you with the soft pedal and new hoses fixed it, I did have issues with dragging brakes and it fixed that as well.
I'll order some and give it a try. Did you have visible issues with your hoses?
No I haven't.Just a thought, but did you check the booster pushrod to master cylinder gap? I think it's supposed to be just a hair under an inch (0.980-0.995?)
I didn't noticed anything as I bleed each line but I will toss some new ones on and hope it does the trick.But have you looked for bulging while someone is stomping the pedal down?
