BKahler
I've put about 3000 miles on the 1992 F350 IDI that we bought a few months ago. From the time we got the truck every time you turn the truck off there has been a fairly strong odor of diesel mainly coming from the engine compartment. At times there was also what seemed like very light
smoking form both sides of the dual exhaust.
I've been using the truck to pull loaded 18' flatbed trailers from Arkansas to Kentucky so most of the driving time I've had with it has been on the road.
This last trip I noticed that although the diesel odor seems to have remained about the same the blueish white smoke coming from the exhaust is more pronounced even at idle. Even more noticeable is the smoking when heading downhill under engine braking. Its definitely noticeable and leaves a cloud behind.
Oil consumption over the last 3000 miles or so appears to have been no more than a quart or so. Which to me seems about normal. The odor out of the exhaust pipes is a very diesel smell. Fuel mileage is not that great when towing, probably somewhere around 7 to 10 mpg depending on the terrain.
So what could be causing the diesel odors and what would be causing the smoke out of the exhaust pipes?
Prior to our buying the truck its prior use was probably a half dozen times a year towing a horse trailer around Tennessee. It only has 150,000 miles on it right now.
Any help would be greatly appreciated.
Brad
Brad
