I know there are probably better places to ask this, but I wanted to take advantage of the wealth of knowledge, we have here.....
I have to rebuild the CV joint on the front drive shaft in an 01 Dodge Dakota with AWD. By CV joint, I mean a splined end that fits into a disk shaped housing which bolts to a flange on the tcase via 6- 8mm bolts. Regular 4 bolt flange on the other end. I find a lot of write-ups on the internet for rebuilding what other people call a CV joint, but what I call a double cardan (the kind with two u-joints...). I hope that made sense....
I have found a rebuild kit for the female splined end and bearing for $100 and a replacement male splined end for the driveshaft for around $20. So my question is, is this rebuildable for a guy with a good tool set and a vise, or is this something that requires a fifteen-gazillion ton hydraulic press and a 30,000 rpm computer balancer? If this is a home job, does anyone know of a good writeup for this? My google searches have drawn a blank.
Thanks!!
Thanks!!
