S-S Brake Lines
Swede
NWIn
Classic Tube says they only have pattern for 4x4 '93/'94 IDI pre-bent lines. What if any is the differance in 2wd & 4wd frame lines??
F350farmboy
The Hornet
N.E Ohio
Actually, NPD has SS brake lines for $195 compared to LMC's $220-230. Price depends on wheelbase
Optikalillushun
Coal Region, Pa
i had to replace the brake lines on my 93 F-150 and all they had were 2wd, so i bought them anyway being mine is a 4wd. they fit like a GLOVE. i also bought mine from NPD which was cheaper than LMC.
dancrowley
danc01
south of Boston
SS brake lines
I sent all the original brake and fuel lines from my 1984 diesel F-250 HD 4X4 pick-up to Classic Tube in NY. They copied them and sent me new SS brake and fuel lines for $450. so they should be able to do them for you. They told me that once they copied the old lines they would store the info in their computers. Dan
F350farmboy
The Hornet
N.E Ohio
Wow $450 sounds like alot, then again you did the fuel lines while you were at it. But I bet they went in really easy cause they were perfect matches.
Does anybody even make SS fuel lines?...other than Classic Tube of course
dancrowley
danc01
south of Boston
SS Brake Lines
Yes Inline Tube makes them. I did brake lines, fuel service lines and fuel return lines. Dan
