RigMaster power units.
PackRat
Buzzard Pilot
Kansas
Serviced both of our RigMaster's, this past week.
Found out several interesting things.
They use the same oil filter, as a Geo Tracker.
The motor mount plate, directly under the oil filter, allows all the oil from the filter to run down the side of the block, and onto the housing floor. A bead of silicone fixes this problem nicely. At least that way, it drains where it can be caught and cleaned up.
The wiring was installed by idiots. One wire package runs under the oil filter, and one runs over it. There is enough slack to recitfy the problem.
I think the little Perkins would make an awesome motor, for a small scooter. It would require a turbo, I think.
Alleycat
