Waystro
No Class
How to remove turbo from 86 F-250 it's an Ats 088 kit thanks
after you pull the cross over pipe off, and unbolt the passnger side manifold, the 2-1 up pipe should slide right off.
thn its an oil line, intake hat, and 2 bolts for te pedistal
Yes, core support and front body mounts under the driver and passenger floor. Soak them good too. One of mine was rusted to the point of not being able to remove it without a sawzall.
Got that ats kit sold?
To lift the cab do I just remove the front body mount bolts..
