SlickCar Trev
Supporting Vendor
Another great holiday gift idea is a remote engine starter. Weather it is for those cold mornings or the warm car shows, you cant go wrong with the convenience of a remote starter. Be sure to click on the vehicle application guide link below to build a system for your specific vehicle and options. If you have any questions please post them up or PM me. Happy holidays!
Build a system with the Vehicle Application Guide
Remote Vehicle Starters and Car Alarms with remote Start
Scytek 2000RS - Remote Car Starter with Keyless Entry
• Two Sleek 5 Button Code hopping remote controls
• Code learning Receiver
• Remote Engine Start For Gasoline & Diesel Engine Vehicles
• Quick Stop Mode (Stop and Go)
• Programable Timer Start Every Two Hours (Anti-Freeze Mode)
• User Select Run Time 12 or 24 minutes
• Start, Ignition & Acc Relays On Board
• 800-1000 Feet Transmitting Distance
• Winshield Mounted Extended Range Antenna
• Keyless Entry (Negative & Positive Door Lock Outputs)
• Tach Sense Learning and Tachless mode
• Brake Pedal Shut Down
• Hood Open Saftey Switch
• Trigger Input Wire for Optional Shock, Glass or Radar Sensor
• Factory Alarm Disarm
• 2nd Ignition / Accessory Relay selection
• Starter-Disable Protection (Relay Optional)
• Programmable Double Pulse Unlock (Nissan, VW)
• Five Function Plug-In LED
• Plug-In Protected Valet/Override/Program Switch
• Remote Auxiliary Channel For Trunk Release, Power Window Control, Etc.
• Built in Flashing Parking Lights Relay
• Complete Installation Manual
Python 413 - Remote Car Starter with Keyless Entry
New D2D serial port performance matched for Xpresskit interface modules
Superhet (HX+) receiver for superior range of 1/4 mile
Virtual Tach eliminates the need for a tach wire in most installations
Bitwriter programmable for simple configuration
Outputs for optional horn and starter kill/anti-grind relays
Onboard XCR relays
4 channel outputs
Two 1-way 4 button remotes
All Required Harnesses for Installation
Scytek 4000RS - Remote Starter, Car Alarm with Keyless Entry Combo
5 Button 2-way LCD Remote Control (2 remotes max.)
Built-In Parking-Light Relay Programmable (+/-)
Plug-in user programmable Coded Override Switch
Plug-in Dual-Zone Piezo Sensor
Horn / Ignition 2 (Programmable) Output
Remote Door Locking/Unlocking with negative outputs
Auxiliary Channel with Selectable Output Types, (Pulsed, Timed or Latched)
User-Selectable Auto-Arming
User-Selectable Auto-Rearming
Remote Panic with Smart Locking/Unlocking
Remote Keyless Entry and Accessory Activation Even in Valet Mode
Remote-Controlled Courtesy Lighting Pre-wired LED, Sensor, and Valet Switch Connectors
Auto Disarm with Auxiliary 1 Activation (Trunk Release Output)
Alarm Trigger Identification
Optional plug-in Door Lock Relay Module
Scytek 5000RS+ - 2 Way Remote Car Starter, Car Alarm, Keyless Entry Combo with LCD Pager
ONE LCD 5 Button 2-way Remote
ONE 5 Button 2-way Remote (2 remotes max.)
Plug-in Dual-Zone Dual Adjust Piezo Sensor
Passenger Unlock Output
Two Auxiliary Channels with Selectable Output Types, (Pulsed,
Timed or Latched)
User-Selectable AutoLock - Instant or RPM dependant
AutoActivation of Auxiliary 2 Output for Comfort closure (windows)
Smart Remote Trunk Release
“ScyNet” network DataPort Accessory Interface and Wizard Software
Python 991 Responder - 2 Way Remote Starter, Car Alarm with LC3 SuperCode Pager
One Mile Range with SST
New, slim 5-button SST 1-Way companion remote control
New Priority 5-button user interface with easy 2-car operation
Control Center with integrated Status LED and Valet Switch
Virtual Tach RPM sensing
D2D serial data interface for Xpresskit D2D serial data interface modules
XpressPort dock for Xpresskit docking serial date interface modules
Onboard Flex Relays for remote start and light flash
Manual Transmission Mode
Car Finder
Advanced remote start functions: Timer Start, Smart Start, RunTime Reset, and more
Fail-Safe Starter Kill
Revenger Soft-Chirp Six-Tone Neo Siren
Onboard Stinger Double-Guard remote-adjustable shock sensor
Warn-Away – low-volume, brief warning signal for potential threats
Inputs for doors, hood and trunk monitoring
Progressive Door Trigger
NPC – patented Nuisance Prevention software
Silent Mode alarming and disarming
Ports for optional tilt, glass break, cabin and proximity sensors
Keyless entry with optional progressive driver's unlocking and ignition-controlled locking
Trunk Release plus 3 AUX outputs
Galaxy Mobile 500 - Remote Starter, Keyless Entry and Security System (Tracking and Security with your Smart Phone)
Complete Security and Remote Start
2 Way Confirmation
Arm/Disarm Alarm
Remote Start On/Off
3 Auxiliary Points
Impact Detector
GPS Tracking
Speed Alerts
Alarm Alert
Geo Fence Violation
Emergency Tracking
Page feature (incase you lose remote)
High pitch 6 tone siren
Onboard XCR relays
4 channel outputs
Timed or Latched)
Car Finder
2 Way Confirmation
Arm/Disarm Alarm
Remote Start On/Off
3 Auxiliary Points
Impact Detector
GPS Tracking
Speed Alerts
Alarm Alert
Geo Fence Violation
Emergency Tracking
