Rebuilding a Dana 71 on a budget!
dieseldirt
Vermont
Does not seem to be much available for the Dodge Dana 70/71 Rear end.
Need to rebuild everything between the axles!
Dana 71 is dually version of Dana 70.
Is there any aftermarket unit available that will be cheaper/better than just buying a whole used rear end?
Happy with the Truetrac I got for my 10.25 Ford/Sterling.
Haywagon
Mn
Look at east coast gear supply or many other gear venders there is also lots of info if you google dana 70 on pirate 4x4 hope this helps
NO_SPRK
User & Abuser
Santa Rosa, Ca
Dana 71 is not only a dually axle.. all first gen dodge axles are d71
Sent from my SCH-I605 using Tapatalk
Haywagon
Mn
Not all first gens are 71's they are the only ones that carry 3.07 from factory mine is a 70 according to the id tag on the cover
NO_SPRK
User & Abuser
Santa Rosa, Ca
My bad.. 71 and 61 are 3.07.... all dodge first gen cummins had 70u thats smooth on the bottom
Haywagon
Mn
Thats true but before we go and confuse people about the million types of 70's we should put a disclaimer that most are pretty simple and common to find parts for just use the old oogoole button and should have no worrys
olsen726
