Evergreen, thanks for the invite!
Will probably have to take a rain check, though, as I'm running later than I wanted since working on the truck has been hellish with the temperatures and humidity. I am working 20 minutes or so and taking a break just to keep from getting into heat exhaustion. Really brutal the last few days, and I'm simply moving a lot slower than I'd like. Wiring in a new water temp gauge in the morning, then will finally be able to do a road test solo on the Castaic grade to check for problems. If all goes well, wife and I will then hitch her up, load up the dog, pull the trailer up to my sister's place in San Jose to pick up my daughter, and then the family is heading up to Crater Lake and points north. I really think she's going to do OK with all the new hardware in the cooling system and a fresh fill of coolant and SCAs. Will report ASAP.
BTW, my block drains came out very easily, and as icanfixall pointed out to me when I started to talk about pulling the starter, you CAN reach the right side plug with the right extension, and maybe a universal. Most of the coolant ran out without contacting the starter motor, and it certainly takes more moisture during a drive in rain. It was nice for my peace of mind to see virtually no corrosion on the inside faces of both.
Take care!
Jim
