pyrometer weirdness and cold starting issue
SPR1NK
Stevensville, MT
so now that i have the new engine in the truck i have a cold start issue, last the truck ran was last night, go to start it around 2pm today, about 80-85 degrees out, Cycle glow plugs for 5 seconds, cranks over, no fire, try it again, fires but runs terribly and white smokes for a like 30 seconds to a minute then smooths right out smoke clears up and sounds great, am i getting air in the system somehow as it sits? Currently has a facet duralift fuel pump, all new injectors and return caps/lines, new filter, new ip, new everything and i can't see any leaks anywhere
as far as the pyro issue, it works perfectly fine as long as i don't use the heater or headlights, but as soon as i turn one of those on the pyro drops to like 100* and doesn't move again until i shut the heater/headlights off, i put a new voltage regulator on it just to see if that was the issue and the volt gauge reads higher now(Factory gauge) but it still does it, bad alternator? Or do i have a short somewhere?
Thewespaul
Bulverde, Texas
Do you loose voltage when heater is on? I would put a clear hose on the inlet to the ip to see if there is air in the line
SPR1NK
Stevensville, MT
voltage gauge drops considerably when the heater is on
just checked voltage at batteries with engine running, getting 14.7
SPR1NK
Stevensville, MT
no, it drops to the second little white mark with the heater on, and drops all the way to the first little white mark with heater and lights on
jwalterus
Made in America
Garrison, ND
you're fine, middle is 14v, it's dropping to just under 12v with everything running
or else the middle is 13 and you are dropping to 11.......
I can't friggin' remember now! LOL
either way you are fine
SPR1NK
Stevensville, MT
so why does the pyrometer drop out when i turn on the heater then if everything is fine?
since i have the multi meter out i decided to check the voltage of the power wire to the pyrometer, heater off 14.7, heater on 13.5, so it has power, did my gauge die?
jwalterus
Made in America
Garrison, ND
try running a ground from gauge to battery
if it still acts up, run power as well
if both to battery fix it, you should run a circuit with a relay
SPR1NK
Stevensville, MT
seems to be the ground, so apparently the place i had it grounded in the cab is no longer a good ground, i wonder why that is
DaveBen
Ukiah, Ca
The cab should be grounded to the frame and the frame grounded to the battery.
Pork_Chop50
He looks kinda hairy and slobbery to me....
Willamette Valley, Oregon
In regards to air intrusion did you also replace the olives (rubber compression fittings) for the hard lines coming from the filter head to IP and into the filter? The final one I've had issues with is the o-ring for the fuel heater connector, which is available through a Navistar/International dealer. Part #1811053C1 will get you the right fit. good luck
SPR1NK
Stevensville, MT
strangely the starting issue seems to have gone away without me changing anything, but i will still be checking all of that to see if air is getting in
Pork_Chop50
A few years ago I had the air issue causing starting issues, but just recently (this winter) I was plagued with similar issues. It wouldn't happen every day, but occasionally it just took a lot of cranking to get going. Turned out to be a weak battery, but it took me weeks to definitively trouble shoot the issue. I say all this because it is likely that your ground issue was causing some cold start problems. Just more food for thought.
SPR1NK
Stevensville, MT
but the only thing i changed as far as the ground was moving the pyrometer ground to the battery
