Project Mosquito Control...
6.9poweredscout
Bleeds IH red...
Northeastern Pa
well i got the tractor pulleys in! they are perfect. i wasable to cut 1.5" off the waterpump to get some clearence for a fan and radiator!
some bandsaw and angle grinder action!
3" between the radiator support and the snout. think i'm going to try to have a hub made to bolt a 6.9 IDI fan on it, minus the fan clutch.
ran a bead of weld around it to help keep the flange on the w/p shaft. this weekend we'll make up some mounts! :D ;Sweet
6.9poweredscout
Bleeds IH red...
Northeastern Pa
is there really any difference between using the tractor or the truck crank pulley? i will use the tractor one simply because i spent $125 on it. but is there any advantage/disadvantage over either? i have plenty of room for the truck crank pulley.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Mounts!
Front support. sill plan on boxing the front and sone triangulation in the corners.
the only thing i'm worried about is the rear trans mounts are right when the old crossmember bolted onto and the trans bolted to. i'm worried if the twisting and weight on the shackles will be an issue..... :confused:
6.9poweredscout
Bleeds IH red...
Northeastern Pa
does anyone know the gallon per hour flow rate of a DT466 waterpump? i called TAPP radiators to help me figure out what rad and fan setup i should go with and they said that would help them figure it out. thanks!
hesutton
The Anti-Anderson
Bowling Green, KY
She's coming along nicely Jon.
Where'd you get the ag pullies?
I might try that route vs. mod'ing a serp setup from a newer DT.
Heath
6.9poweredscout
Bleeds IH red...
Northeastern Pa
going to try to fit dodge lift springs under the truck tomorrow, see how much they sag. got the D60 mocked up with the stock springs. i think IH expected a D60 to be next to the oil pan at some point in its life!
more to come!
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Went with some 4" chevy truck springs. after 3 sets of busings we had to order them direct from skyjacker. looks like it will work out pretty good!
starting the firewall, step 1. unfortunately it got late so we called it a night.
before leaving i jacked the back up and leveled the cab. about 24" to the bottom of the rocker. higher than i wanted but it'll do!
hesutton
The Anti-Anderson
Bowling Green, KY
That's going to be one freak'n sweet rig Jon. Hope it's done by July and...... you bring it to the rally.LOL
Heath
morerunner
