Premium quality 4.5-Inch Lift Kit by Rancho for F-150 at CARiD - In Detail!
carid
Supporting Vendor
NJ, Cranbury
Folks,
Greg is back in the shop and it means that another useful product review has recently been rolled out on our CARiD Garage YouTube channel.
This time we've decided to add more height to our fresh F-150 project truck and picked an amazingly engineered 4.5" x 3.5" Front and Rear Suspension Lift Kit from Rancho to top off this build. Developed to be a perfect fit for all 2017-2018 Ford F-150 trucks, this premium quality 4.5-Inch Lift Kit will provide you with almost 5 extra inches front and 4 extra inches rear above the ground, which means the best approach angles and improved ground clearance to you. Guaranteed to offer exceptional performance and durability, it will also ensure proper driving experience, and allow you the installation of bigger wheels, up to 37" in diameter. Built for quick and easy installation, this kit consists of CAD designed components, which ensure a precise fit. It comes with all the hardware required for the successful install, yet you'll still need to buy a few extra parts to get the job done.
4.5" x 3.5" Front and Rear Suspension Lift Kit by Rancho for 2017-2018 Ford F-150 at CARiD.com
Notes:
* Max Tire Size: 37";
* Requires replacement Rancho shock absorbers and replacement wheels;
* Replacement front driveshaft may be required;
The Rancho lift kit includes:
* (1) Subframe (Part Number RS176880B)
* (1) Left 4.5" Knuckle (Part Number RS176753)
* (1) Right 4.5" Knuckle (Part Number RS176754)
* (1) Front Left Diff Drop Bracket (Part Number RS176881B)
* (1) Front Right Diff Drop Bracket (Part Number RS176882B)
* (1) Left Aft Diff Drop (Part Number RS176883B)
* (4) Cam Bolt Assembly (Part Number RS176578)
* (4) Hex Cam (Part Number RS176858)
* (2) Sway Bar Drop Bracket (Part Number RS176579)
* (1) Skid Plate (Part Number RS176884B)
* (1) Front Driveshaft Spacer (Part Number RS176586)
* (2) Front Brake Line Bracket (Part Number RS176780)
* (1) Rear Drive Shaft Spacer (Part Number RS176691)
* (4) U-Bolt 9/16-18 X 3.16 X 12 (Part Number RS740017)
* (2) Winged Spacer Block (Part Number RS15104)
* (1) Parking Brake Cable Drop (Part Number RS176748)
* (1) Rear Brake Hose Drop (Part Number RS176314)
* (1) Vent Hose (Part Number RS860749)
Installation Instructions: https://www.carid.com/images/rancho/items/pdf/rs66505b-installation-instructions.pdf
Get your Ford equipped with the best off-road parts only, ensure its ultimate durability and reliability and enhance its performance and appearance with Rancho Performance Suspension products at CARiD.com.
Cv axle
