aofarrell2
Turbo Desirous
Sorry if I got this in the wrong section, it just seemed most appropriate as its mostly about IDI... Anyways, heres the situation: Currently I've got a 1989 Ford F350 with a 460 and E4OD auto (2WD). The body and interior are in near perfect shape, and the engine is weak. Tranny shifts tight, I'm just dropping in a new front seal and torque converter. So that's not a concern as far as power burning the tranny out.
Here's my contemplation: I'm going to go look at a 1986 Ford F350 with a new 7.3L IDI diesel (so I've been told, I'll verify before I buy). It is not turbo AFAIK. What I've been wondering, is since the 1986 is a complete truck,how hard would it be and what would be involved in swapping the 460 out for the IDI since I'll have virtually all the parts except the dash instrumentation and the diesel ECU for the E4OD, which I can grab very easily around here.
It seems to me that the mounts might be the same or easy to swap? One guy said they were the same elsewhere. Any ideas here?
The only other thing would be the bellhousing pattern, it seems that it can be modified to match the diesel bellhousing pattern by some drilling. Is this true? I'm not worried about the tranny not being able to handle the power, as it's built to handle a much more powerful engine already (the 460), and I'm not intent on turning the engine up much if I turbo it.
I could get my fuel tanks out of the 86, and my fuel lines &c.
Anything else I'm missing?
