Popping from intake
screw that...
YOU pm ME! with your address.
ill get them on todays truck.
save your f'n cash for parts :backoff
ill even throw you a set of 6.9 injectors too.
they worked fine when pulled. engine had a rod knock.
but you have to send your old injectors to Russ.
Waystro
No Class
South Texas
screw that...
COOL!! Thanks! It's a deal. Sending Pm now.
man your Awesome. Thanks :angel:
I can send you the 8 Wellmans that I was using for the test, there all good. If you need a controller I have some brand new ones, but there the first gen controller, they work just fine, you will have to use your relay tho. PM me with addy.
You should take your valve covers off, look for a loose rocker and check the lift rods, when the rocker is up, the valve is closed and the lift rod should be still tight up against the rocker, if loose then the lifter is stuck. just have to check all the intake valves. since the popping came up the intake horn. Since it quit popping, you may have just had a stuck lifter. If your a bit low on CC oil, add a quart of ATF to the oil.
How long ago was your last oil change?
Waystro
No Class
South Texas
Don't know if the controller is bad are not it's probably been on longer than the Glowplugs.
Its been awhile since I've changed the oil. I'll pull the valve covers tonight.
Pm sent.
Let me know how much on the shipping and I'll paypal it to you.
Waystro
No Class
South Texas
Just wanted Say Thanks to IDIoit And OldBull8 And Type4 for Helping me out on the parts. :angel:
And just hope I can Pay It Forward and help fellow members Like Y'all have Helped Me And Repay You Guys. Thanks :hail:hail
no thanks nor praise needed. now stop bowing and get your truck running right.
not all of us cali folks are prissy lill b!t@#e$
dont ************ out there LOL
but the electrical storms may be worth it
Waystro
No Class
South Texas
I'm Getting There Slowly but Getting there no less. LOL LOL
Waystro
No Class
South Texas
Might Have Found my problem.
Took The drivers side valve cover off. Everything Looks Oiled. But the rocker arm at the far back is way loose
Same with the 3rd up :eek:
So now it's time for a Stupid Question. Would that cause the popping if those 2 Rocker Arms are Loose. They have maybe 2-3 inch of Play(Side to Side Up Down)
Waystro
No Class
South Texas
Ok the intake valve? Lift Rods? That's Conected to the rockers Turn side to side freely
That's definitely not good.
Looks like it's time to pull the intake and replace lifters, pushrods and rockers
Waystro
No Class
South Texas
Dam! Is this something that is semi easy to do?
I don't want to tear into it and it be way to much
This sucks.
Was it the starter fluid that did it?
chris142
SoCal
Its been my experience that these trucks start easy even without gpow plugs. I only use mine under about 50f. It may take 5 seconds of cranking but I'd rather burn out a starter than pull the heads.
bbjordan
Snow Monkey
Ashern Manitoba
Depending on how well the engine has been maintained, you may just need to disassemble the lifters and clean them up.
