OK, NEW idea, dt466
LSXJ6
ALTON, IL
I have now completed the running driving xj6, next will be a 94 Cherokee 4wd project, I'm gonna try for a dt360 thistime and actually make it work, my question is, would an Allison 545 and divorcd 205 be in the general area of working for a jeep of this nature? The reason for the swap will be low end power for the trails period. I've done a cummins swap and this time would like to use a IH motor. Hell is it POSSIBLE to use a 466? I have both motors now, and all parts do to ether swap for either.
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
i dont think the unibody would like that weight much. plust the over length of everything just would not fit. there would be no room for a rear shaft.
LSXJ6
ALTON, IL
understood, I may just use the 360 and machine an adapter plate for a decent 4wd trans, I wasn't sure how much engine room a jeep had but I also haven't been able to measure my 466 since its still in the truck.
I know the big ******* will fit in a pickup with firewall modification, perhaps ill save the motor for somethin.g like that.
hesutton
The Anti-Anderson
Bowling Green, KY
That allison isn't a good one. Not much support (if any) in upgrades and it has a very low HP rating.
A 4BT would be an easier fit in the Jeep. The DT360 may be too dang long............. the DT466 certainly will be. Add the length of a medium duty trans and Corey is right, there's not much room for a driveshaft.
But, I like where you are going.
Heath
I also think it'd be to long. Being that Cherokees have a short wheelbase already.
Just a question and I know you already have a cummins to use, but what do you think of Detroit's?
tbirdfiend281
Eldersburg/Sykesville, MD
You need a 4cylinder diesel for the Cherokee. They had factory ones overseas, a 2.5L. You could also source the 2.8 out of the liberty if you choose. Is the dt360 about the same size as the 466?
nevrenufhp
torque ******
Sacramento
The 360 is about 1.5" shorter in length and 3" less in height.
tbirdfiend281
Because it's like a Chevy 350. After a while it gets boring seeing one swapped in to a pickup. Plus, the DT360 is a better built engine. It just didnt get the P-pump it sooo needed.
uhhh, dt motors had p pumps before they where heui. I actually think the DT360 is a p pumped motor, I don't think they made a heui one, though I could be wrong. We just did a pickup tube in a p pumped dt466 dump truck tonight
nevrenufhp
torque ******
Sacramento
I was talking 360, not 466. I'm well aware of the P-pumped 466, I drove one yesterday that has a #0 fuel plate. The 360 came with either an MW-pump or A-pump. Some people mistake the MW for a P, because the main body looks the same, and the big governor housing. I have yet to see a factory installed P-pump on a DT360. To be sure, look at the numbers on the pump. Look for either of these: PES6A950 or PES6MW950 or PES6MW100. The dump truck's 466 would have a PES6P100, possibly PES6P110(if it was a hi torque).
tbirdfiend281
I have never actually seen a dt360. Closest thing was a dt408 that came into our shop, that was a p pump truck. I do have a service manual tucked away that has a dt360 on the front of it, and it looks to be p pumped. I will gank it tomorrow and read through it, see if it says that it is p pumps. I dont see why the dt466s would have them and the 360s wouldnt, not much sense there.
Andertusa
S.W. Minnesota
I can't say much about the performance of the DT466 or the DT360, though I have some anecdotal info regarding the DT360. I've never really worked on either, but I drove a school bus with the DT360, and I LOVED that bus, L-O-V-E-D that bus, it would do almost everything I wanted it to, except go fast, 59MPH was the MAX, but I loved that ride.
