Hello (again)
First, I'm trying to start a debate in general...if you had a choice either way, would you prefer a straight-mechanical gauge or an electric gauge for oil pressure (and water temperature)?
It seems to me that both have their ups and downs; with a mechanical gauge, you have oil coming into the cab if the line breaks...but with an electrical gauge, it's functionality depends on the electrical system and on an electrically-operated sending unit.
Second, if you had a choice, where would you put an oil pressure sending unit on an IDI, assuming that the stock gauge is permanently inoperative? I've heard of three options...either put the sending unit where the factory sender was located, put the sending unit in a plug in the block near the oil filter, or putting it in a T-fitting with the line going to a turbo (if a turbo'ed engine).
I don't especially want the sender where the factory one was located; it's too close to the turbo for my confort level (in addiiton to being nearly impossible to get to), but if it truly is the place where you're going to get the best reading, I'll figure a way around it being close to the turbo...
Any thoughts would be appreciated, and a civil debate would actually be desired. Thanks!
Oh yeah, one more thing...if a mechanical oil pressure gauge is failing, does it "generally" fail low or high? I haven't been able to do an active comparison, but I think my oil pressure gauge is sometimes reading lower than the actual pressure...
Thanks again
Thanks again
