Oil feed line for turbo
chickendrank
Colorado Springs, Colorad
I'll be building the oil feed line and just wanna make sure I'm tapping into the right spot as it seems my oil pressure sender is mounted different than any other 6.9 I've seen, here's pics of what I believe is my oil pressure sender and line.
Sent from my SM-G530T using Tapatalk
jwalterus
Made in America
Garrison, ND
neither have I.....
but I know one thing I'm doing whenever I yank the engine outta the truck next! LOL
They do that to keep the vibration from killing the sender.
BINGO.... We have a winner. Our idi engines create plenty of vibration from high compression and the injection pump pulses pushing fuel thru the injectors. Ever wonder why the feed line from the mechanical lift pump is hard connection at the pump but those silly olives at the filter head?? Thats to stop any vibration from traveling and breaking things. Your isolation line is a great idea. What year is your truck?
chickendrank
83 f250 an old diesel mechanic used to own it before I got it
That figures, the bracket is on almost all medium duty fords with a diesel. A 3208 cat will kill an oil sender in 1 day.
was kinda hoping this post had a visual aid on other options to pull oil from....
please?
Iirc, there's one on the oil cooler header. Which is where banks turbos draw from.
I like the ats 093 instructions using the rearmost port above the pan rail. That is what my line kit is designed to do.
Wait, y ou said visual,,, here. red circle ish area.
perfect! thanks!
did you get a PM from me the other day Russ?
Yes. Ill let you know. But we will have the dog.
BTW, that is the first typ4 cam in that pic.:D
Those core plugs do not look lije factory replacements....
They are stainless that I put in with the 2 hammer method. Had I known originals were stainless I would have never removed them.
Those plugs have seen 240* for 10 miles. Maybe the paint holds them in.
Alleycat
