Sounds like it's been done before.
Anybody break off an aluminum adapter?
So what is the weak link? Stock front hubs?
I'm not planning on rock crawling, just want a really reliable transfer case. It seems with high mileage the BW1365 is just a time bomb waiting to go off. Are there mods that can be done to the 1365 to make it more reliable?
One of our members here broke the aluminum adapter on his T19, don't recall the details on how it happened tho. Besides, you have a ZF5, ain't the adapter of that kinda-sorta part of your transmission case? If so it could very well be stronger than the simple bolt-on kind T19s run. Downside would obviously be that if you break yours, well, you know.
Weak link, till you start running creeper ratios and large tires there is probably nothing to really worry about in that D50, just make sure your U-joins are in good shape.
The only real problem with the 1356s IMHO is the oil pump setup, it's just a cheesy design from the factory. Supposedly there are mods that can be made to address this issue, I've seen them mentioned all over the place but I've never seen them explained as to *** said mods actually are.
When I looked at the 205 behind my zf I thought about making a brace to go to the 6 bolt PTO plates on both sides to distribute the weight but I never had a problem with the 1345's or the 1356's so I never bothered. I just wanted one so I could have 3 sticks in the cab
The problem with the 205 is its weight, thing is almost as heavy as the transmission itself! Except the transmission is supported on both ends, while the 205 is just hanging way out there. Personally I wouldn't worry about bracing a married 205 on the PTO side, it's the front driveshaft side that rally torques the transmission flange good - that's where the additional factory mount goes, and IMHO it is not one of those factory setups that should be omitted. On a different note, which twin-stick setup did you use, ORD?
