&%$ NO CLUTCH!
Nickbf2504x4
ATV Racr-IDI Driver
Colorado State!
Who has a fix for that ridiculous plastic bushing that goes on the rod that links the clutch pedal to the slave cylinder? I go through one every thousand miles or so... then i lose my clutch operation all the sudden when my pedal falls to the floor
I have tried to put a small hoseclamp on but to no avail...keeps falling out
Thanks again ;Sweet
Freight_Train
Traitor to the brotherhood
Gadsden,Al
Ummm,being a slusher....what bushing is this.Got a picture,part number,blueprint?Might try and sneek into the tool room at work and fab up a metal one.....I really need to get a lathe and Bridgeport one of these days.hmmm,I wonder if I could make a custom program for my CNC Lathe while no one is looking. :Sly
your pivot arm is no good. A little wear will cause the pastic bushing/retainer to wear out prematurely. The P/n should be in the "parts bin" article, if not I will post later on this evening when I get back.
Nickbf2504x4
ATV Racr-IDI Driver
Colorado State!
i had seen that heim joint fix...but was looking for a more stock fix considering i am away at school and have no power tools :puke:
Towcat i didnt see a p# listed for a pivot arm in the parts bin...unless im cookoo
