1800joedaddy
OK, so I go on-line this morning and snag a running 95' plane jane f250 PSD w/a 97' engine and 5speed for $500. The story is the valve cover gaskets are trash and the guy over tightens them shorting 2 injectors.
A.
Is this BS or could that happen?
B.
What should I look for if this is BS?
Here's the skinny, I've got an awsome 97' supercrew HD F250 shortbed. It runs like a streek of **** but has a serious drinking problem. I've been on-line asking about doing a cummins swap then this PSD falls into my lap.
If I can get the PSD running right how hard is the swap?
I'm assuming the fuse box should accept the harness from the doner.
The engine should clear because both engines were offerd in the same body.
The gauge cluster should swap so I have the GP light.
What else am I missing?
A.
B.
