New to me trailer rims hmmmm ???
CESMITH
1986F250 6.9
New Springfield Ohio
Lowboy tires and wheels
You gota make sure the rim is seated on the back and tighten the nuts evenly around the wheel, if you get them coocked on there they will wobble. they work ok and they will haul alot of weight but I got rid of my traler with them on cause I couldnt get them ballanced. They were oddsized 14.5 we called them daton wheels (idont know if that is right)cookoo
trapper
Boom Boom
Chatsworth Georgia
Those are Dayton-type wheels, take the nuts off and the lil metal tabs and it will just be a center-less steel wheel , it shouldn't be a 2 piece rim, plus Ive only seen 2 piece on big trucks so it should be straight forward
Jake_IN
West Lafayette IN
I don't think those are split rims, all the split rims i've seen it was the very outer ring piece by the tire bead that split and it doesn't look like it to me. I've seen these on a lot of trailer applications. Friend of mine bought a trailer with these and first thing he did was scrap them for newer stronger axles that did have a funky tire size. Our international 9600 cabover has rims that bolt up similar to that. You put the first rim on then a little ring then the second rim. Then run the bolts up snug and check the rim to see if its straight or if ya need to adjust it again. It's a PITA. Back to the topic though im pretty sure your axles are just cheap trailer axles that around here are worth what scrap yards pay.
trapper
Boom Boom
Chatsworth Georgia
yes they do use them on a few apps because they will hold more weight than a bud style rim but be warned be sure u set them true and evenly or they will wobble
Oh and jake 2 piece rims are actually pretty much illegal and tire shops will not mess with them due to the fact that so many people has died from 2 piece rims when they basically explode on you
Jake_IN
West Lafayette IN
Not sure if the name applies to trailer rims but I finally remember what we called them. They are Dayton style rims.
Jake_IN
West Lafayette IN
Yeah I'm thinking of the rims that have the lock ring. Not sure if they are just called "Lock ring style" or what but a farm i helped haul for had a grain truck that had the lock ring style rims. Also yeah no tire shop will even touch split rims....even with a ten foot pull.
Brimmstone
Those are 14.5 house trailer rims. You can find tires with a killer weight rating for those. Only real issues to them are getting them balanced and getting them centered on the hub.
Brimmstone
Truck tire shop would be your best bet. Most normal shops freak when they see a centerless rim
bob123456789
